Windows 8.1 fileopen dialog
pauldaytona
PostPosted: Fri Nov 01, 2013 2:10 am    Post subject: Windows 8.1 fileopen dialog Reply with quote
I upgraded my desktop from Windows 8.0 to 8.1(x64). Now in tunerpro when I want to open an xdf or bin, when I have the fileopen dialog, as long as I select a file in the directory where I'm in, no problem, but when I select a subdirectory from where I am at the moment, and doubleclick that or choose "open" it does open that subdirectory but at the same time tries to open the last file, marked at the bottom line. That does not work because the file in that line is not in the other subdirectory. Then get errordialog: Select Bin to open: xxxx.bin this file doesn't exist, create the file?
PostPosted: Thu Nov 14, 2013 7:27 pm    Post subject: Reply with quote
Hi,
Any chance the files you're trying to open are in the Program Fiiles subdirectory? If so, don't open your files from there (as I believe you'll need admin privs to do so). Instead, store your files on your desktop, your documents folder, off the root of a drive (e.g. "e:\foo\myfile.xdf") or just about anywhere else.
Let me know if that gets you working. If not, a video of your screen during a repro of the behavior would be helpful.
Thanks for the report!
-Mark
_________________
pauldaytona
PostPosted: Sat Nov 16, 2013 6:31 am    Post subject: Reply with quote
here is a movie that shows it:
http://youtu.be/kij8jdPzRa8
No does not depend where files are, I have full rights. Files were in same place before upgrade from win 8.0 to 8.1, there it worked
PostPosted: Mon Nov 18, 2013 10:54 am    Post subject: Reply with quote
Could it be a Google Drive issue in 8.1? That's certainly a substantial "unknown" that's in the middle, here.
_________________
pauldaytona
PostPosted: Wed Nov 20, 2013 2:48 pm    Post subject: Reply with quote
No unfortunately not. I put a bin file in d:\ browsing to d: and opening gives the error, and after I opend the one in d:\ and browse to c: to open another one, same error.
PostPosted: Wed Nov 20, 2013 3:00 pm    Post subject: Reply with quote
Alright, I'll take a closer on my 8.1 machine.
_________________
The1
PostPosted: Fri Oct 03, 2014 6:11 pm    Post subject: Reply with quote
i have this issue as well with windows 8.1, like the filename box needs to be cleared when the dialogue opens.
Turbosport
PostPosted: Fri Feb 27, 2015 1:38 am    Post subject: Reply with quote
This is the same as my issue I posted.
The1
PostPosted: Mon May 25, 2015 4:44 am    Post subject: Reply with quote
still same issue here on 8.1 machine with latest 8606 version
Turbosport
PostPosted: Mon May 25, 2015 4:46 am    Post subject: Reply with quote
Yes still a real pain
pauldaytona
PostPosted: Tue Jul 05, 2016 1:40 am    Post subject: Reply with quote
Please Mangus, take another look in it, I have all PC's on windows 10 and all have it.
PostPosted: Tue Jul 05, 2016 7:50 am    Post subject: Reply with quote
You're telling me you have this issue on Win10? I run Win10 on all my machines and haven't hit this.
Note that TunerPro uses a standard Windows API to bring up the file open dialog. Windows does all the work to display the box and make it function. Although I am provided a set of parameters which control, at a high level, the functionality, details like this are likely issues in Windows itself.
_________________
richrich
PostPosted: Thu Jul 28, 2016 2:27 am    Post subject: Reply with quote
Agreed. Still get this on all 3 individual Win10 PCs I use.
Thought it would have been fixed by now.
PostPosted: Thu Jul 28, 2016 6:46 am    Post subject: Reply with quote
OK, I can reproduce the issue now. I'm not sure this is something I can fix (again - the open file window is entirely controlled by Windows), but let me look around.
_________________
PostPosted: Thu Jul 28, 2016 8:08 am    Post subject: Reply with quote
This is fixed for the next build. =)
_________________
pauldaytona
PostPosted: Sun Aug 14, 2016 11:06 am    Post subject: Reply with quote
Glad you have found a solution. Something in windows will have changed.
I can test it before release if you want. Just send me a version
The1
PostPosted: Fri Oct 21, 2016 1:51 pm    Post subject: Reply with quote
just a tickle to see when the next version is coming out? So we can have this issue solved Smile
PostPosted: Sat Oct 22, 2016 5:51 pm    Post subject: Reply with quote
Sorry for the delay. I'm at the tail end of implementing a more "involved" feature that has me at an inconvenient point to spin a build.
I'll try to get something out in the next week.
_________________
Avinitlarge
PostPosted: Sat Oct 29, 2016 3:46 pm    Post subject: Reply with quote
Im glad for have managed to sort it out, It is So annoying. Looking forward to the next release without this issue
pauldaytona
PostPosted: Sun Jan 15, 2017 6:37 am    Post subject: Reply with quote
case solved thanks Magnus.
