Why Tunerpro v5 doesn't read the correct addresses?
deltaza
PostPosted: Tue Jun 14, 2016 6:28 am    Post subject: Why Tunerpro v5 doesn't read the correct addresses? Reply with quote
Hello
I'm trying to understand why with a bin with addresses from 0 to 8000, Tunerpro reads only if you put....addresses STARTING from 8000
I mean, Tunerpro read not values at 0DD0 (for example) where the value IS, but only if you put the address as 8DD0.
For example...that address is the "turbo duty cycle" 4x16 table.
If you put the correct address of 0DD0, the program reads 00 for all the values.
You have to put the address as 8DD0 to make the program reading.
Try this xdf: http://www.tunerpro.net/download/bindefs/Fiat/FiatCoupe16VT_KJ.xdf
And this bin: http://www.berlinasportivo.com/Technical/ECU/files/EVO2-WH4WG%5B1%5D.P8.PTP_CG.6160021601.BIN
Other problem: emulating on the road, with Ostrich, in that table the yellow box doesn't light correct values and moves in a apparently random way
PostPosted: Tue Jun 14, 2016 1:55 pm    Post subject: Reply with quote
See the "Base offset" field in the XDF header (Ctrl + F2)
_________________
deltaza
PostPosted: Wed Jun 15, 2016 1:20 am    Post subject: Reply with quote
AH! Thank you very much...so it isn't a bug...sorry! Embarassed
Why did, who make that xdf, translate the addresses after 8000?
I don't understand the utility.
But could it cause also the random reading on the road? Confused
I mean that the yellow box, during emulation, doesn't go in the right places...
