Hello from Europe.
I am currently using TunerPro with Ostrich 2 and LM-1 to do some live mapping.
But my question is how can I get the LM-1 values dirrectly to my Tunerpro?
Do I need some other emulator than Ostrich, or can I use some other tools to get this happend?
Any help would be appreciated.
The car its used on is a Audi A4 1.8Twith me3.2.
Regards
Es
TunerPro, Ostrich 2 and LM-1 question
I believe there's a serial interface available for the Innovate controllers. With that, you may be able to use the Innovate O2 definition available on the website to log your wideband data.
Not owning any Innovate products myself means that I can't verify this for you. Hopefully someone else with experience can chime in.
This may not work with your Audi, but I logged my wide band data by redefining my LM-1's analog output to read from 0 to 5 volts and routed that output to one of the unused input lines (in my case oil pressure) on my MEFI engine controller. Here is a link to how I did it.
http://www.carols62.com/ramjet/wideband.html
