How to make screen shots
POZE
Post by POZE »
Can anyone explain how to copy screen shots of tunerpro? The only option that I can make work is export to text. I would like to print some VE tables as they appeared on the screen. Thanks
cbernhardt
Re: How to make screen shots
Post by cbernhardt »
POZE wrote:Can anyone explain how to copy screen shots of tunerpro? The only option that I can make work is export to text. I would like to print some VE tables as they appeared on the screen. Thanks
If you are using Windows, when the screen you want is visible, press the PrintSC key. This will copy the current screen to the clipboard. If you have picture editing software, open that program and paste the clipboard image. If you do not have a dedicated editing program, open Windows Paint, click on Edit, then Paste the image.
Charles
On Windows Vista and newer (win7, win8), it's easiest to use the snipping tool. Open the start menu and type "snipping" and it'll pop to the top of the search list.
POZE
Post by POZE »
Thank You
