First Post.
Thanks to Mark and anyone else involved in making this powerful tuning and diagnostic tool available.
I would like to invert my WideBand A/F trace as I am so used to seeing rich as up and lean as down. I think it a age problem I have.
I hope it's possible. Just cannot find a way to do it. TIA
Cheers
Dick
Can a "Value" item's trace be inverted
by trace, i assume this is in a monitor view....
i can see a few solutions, some working better than others. changing the min/max range, along with the equation to display negative numbers would do such a thing and leave good data, just with the wrong sign in front of it.
creating an AFR "error" value, dividing target AFR with read AFR(commanded 13:1 and reading 12:1, 13/12=1.083), min/max could be something like a .5 to 1.5 range.
- Six_Shooter
