New to TunerPro, here is my mission..
928GUY
Post by 928GUY »
I am being asked to capture BIN files from a stack of ECUs for comparison in a college project, where 'tuning' is the project goal in a summer school project.
I will have these allowable ECUs in the cars:
0 261 200 153
0 261 200 173
0 261 200 351
0 261 200 380
0 261 200 382
0 261 200 524
0 261 200 525
0 261 200 526
I have a GQ-4X reader, and I believe I am capturing the BIN files correctly (I end up with 32k BIN files). I am yet to confirm if I am doing that step properly yet.
BUT..do I need to locate a separate XDF file for each CPU model? Is there a good SINGLE file I can use to review each student groups work at the end of term?
I have loaded this XDF:
http://www.tunerpro.net/download/bindef ... _sw705.xdf
And the 32k bin file I read from an ECU chip..
And all of my fuel maps cells are "255", so clearly, Ive bunged something up. :)
Thank you all, and I look forward to learning in this community.
:P
Guybrush
Post by Guybrush »
Every single cpu has its own xdf file.
So,when you see 255 at cells means that this xdf is for another cpu with different address memories.
But there is a possibility for an xdf to match with 1 or 2 bins only when is for the same car,model etc.
928GUY
Post by 928GUY »
Got it..so that complicates the mission, because there are a # of BMW supplied ECUs, but I cant find XDFs for all of them.
Thanks.
Guybrush
Post by Guybrush »
928GUY wrote:Got it..so that complicates the mission, because there are a # of BMW supplied ECUs, but I cant find XDFs for all of them.
Thanks.
Post the ori file(bin) here if you want and i will try to make the xdf file you want :wink:
taiajam
Post by taiajam »
Do you have the original file of the 0 261 200 380 ECU?
I need i, i can help u with your school project
