0 261 200 350 Motronic 1.2 (E34 M5)
DmcL
Post by DmcL »
anyone done any work with this ECU before? any idea where the rev limiter is and what the raw values in the bin file are for the limiter so i can find it? also is there a MAF map on these? havent noticed anything large-ish resembling a MAF map as of yet but have not spent much time looking either..
finding part throttle maps among others is very easy though.. notice the axis descriptors are not the same as 1.1/1.3, appears to be 3A for RPM instead of 3B and load appears to be 42 instead of 40. the majority of the bin file is much the same as 1.1/1.3 though, never even knew or bothered to look and see if there was a M1.2 till now :lol:
EthosMotorsports
aboutton
Post by aboutton »
send me the file my friend, tuning@lordlogic.com
HyperBoost Tuning
Tony Ouneissy
Lebanon
hussain
Post by hussain »
aboutton wrote:send me the file my friend, tuning@lordlogic.com
:D.
Hello guys I am back!
Boost makes me happy......
hussain
Post by hussain »
Miss you both,
for the m5 350 ecu I have a racing base map and the rive limit is way
To much for the engine the same base map you do have tony we have
An m5 for my friend when he instal the chip he due to higher rivlimier the
Timing belt chain lock broken twice so guys what revlimeter do you sugest
And can you make it happen and decrease it?
Fuel octan is 91.
And one more thing is there any video tutorial on how to tune tuner bro on the
Ostrich 2.0 map trace and all edf file and base map?
If its not avalble its better we make one.
I have a 173 ecu I just fix the ostrich 2.0 in the ecu need xdf file for the map I have
To play in rive limiters and if there is any chance to maker the system a map
Sensor it is for best friend project !
So guys neen your help in this one we have a mustng dyno in here
We need to keep the oem ecu alive!
For the time been its a n/a project 335 I will write about the full swap for more
Details.
We have been tuning with map ecus and haltech but for the low
Budjet guys there are no sulotion rather than chip.
Find this video tutorial https://www.youtube.com/watch?v=HpUaeiJ ... ata_player
