Not sure if this is on the list or not, tested this myself on 3 computers with xp/win7, when changing from one adx to another if the log file isn't closed the next log file opened will be blank in the monitor graph, from then even closing the log and reopening will not work, another seperate log file has to opened then go back to the one your trying to use to get the data to show up.
Hope this explains it, sounds as if the data isn't being reloaded every time you open a new log file.
monitor window blank when changing log file
You're sure the ADX you're opening was the one that was used to create the log (or a derivative of it)? If not, the log and ADX will be mismatched.
You might also try re-opening the log when you encounter this.
Meanwhile, I'll take a look next time I'm in front of the code.
so far i havn't had the blank log issue back again with the new verison though now i have another issue.
Using the same ADX, if i have one log open and goto load another log recorded with the same adx sometimes it will not load it, the loading bar across the bottom doesn't load the log file. It's like that log file is stuck in there and wont let you open another log file, i have to change ADX files then i can open another log and it will load the log file.
