1988 S10 with 3.1L V6
5ft24
Post by 5ft24 »
Upgraded my 2.8 to a 3.1. Looking to add fuel at 4000 RPM and above, as above 4K it leans out and melts spark plugs. The VE table only goes to 3200 RPM. Where do I need to go to add fuel for 4000 and above?
EagleMark
Post by EagleMark »
What ECM/Mask ID?
2.8 and 3.1 TBI are usually same size injectors, but I'm sure the bin is differant?
Post by robertisaar »
i would assume there is a VE adder table....
but as Mark pointed out, need to know what you're playing with first.
5ft24
Post by 5ft24 »
EagleMark wrote:What ECM/Mask ID?
Sorry... 1228062 ECM, ACJH broadcast code, $4E mask
Added an adjustable FP regulator as well.
there is a VE adder table at 39E for dealing with fuel at higher RPMs.
not sure which XDF you're using, but this is the one i generated, has some more stuff than the common one.
http://www.wikifortio.com/835826/my 4E.xdf.zip
5ft24
Post by 5ft24 »
robertisaar wrote:there is a VE adder table at 39E for dealing with fuel at higher RPMs.
Now it makes sense... VE above 3600 stays at the 3600 RPM value PLUS whatever is in the VE Adder table...
Cool!
Thank you!
