Using T/P version4; I've located three ads files from both the T/P website and the Moates website, but they're pretty limited. The biggest problem I'm having is finding a spark advance table in the editor...........am I doing something wrong?
The three ads files I found are: A20.ads, 1226870_85_updated.ads, and 1226870_85_updated[1].ads
Thanks!
Need help with '85 Corvette ads
ads file is for data logging. You need the xdf file to find timing table in bin.
http://www.gearhead-efi.com/Fuel-Inject ... rmation-1F
Unless it's in the ALDL data stream from bin file you can't. Unless you re write your bin file to include that information in ALDL output.
I looked at A20.ds file and it has a bit for it but says
21 UNLIMITED SPARK ADVANCE Not used !
Now if you set up Data Tracing in your XDF and ADX file, you would use engine speed and map kpa if that is what the x and y axis is in your spark table. Then while data logging or playing back recorded data it will have a bubble dance around the Main Spark avance table open in your XDF file!
http://www.gearhead-efi.com/Fuel-Inject ... Pro-How-To
